[ICEM] problems with 90 elbow and make sure y+<1 |
March 31, 2016, 21:41 |
志新高(Zhixin Gao)
Rep Power: 11 |
I use ICEM to get structure hexa mesh. Here is how I block the elbow.(due to y+<1, the first layer is less than 0.00085mm) But when I set nodes number either more than 33 or less than 33 in the Circumferential direction, there will exist negative volume By the way, the contours of y+ is also strange(this time I use more block at the elbow part) this is the cell mass fraction of first layer, and is seems to be wrong. so anyone can help me? Thanks. |
[ICEM] Pipe 90 elbow joint meshing issue | sihaqqi | ANSYS Meshing & Geometry | 25 | April 17, 2015 04:59 |
[ICEM] Blocking an elbow (block not conforming to geometry) | llrr12 | ANSYS Meshing & Geometry | 0 | January 22, 2015 22:06 |
[DesignModeler] Parametric elbow pipe | thaenan | ANSYS Meshing & Geometry | 0 | May 18, 2012 16:26 |
Simple pipe layout - 2 pipe joined by a 90 degree elbow | GamFlu | ANSYS Meshing & Geometry | 1 | April 26, 2011 07:56 |
Creating inflation layers for elbow with airfoil ! | Aplus | CFX | 1 | March 13, 2006 22:22 |
