[Workbench] Problems following tutorial: extrusion operation does not show IMPRINT FACES |
April 16, 2016, 03:23 |
SAMRAT MANDAL
Rep Power: 9 |
Please help.I want to do transient analysis on welded joint.So for moving heat source I have to select multiple patches along the weld joint.From tutorial I came to know that it can be done by imprint faces while extruding lines,but when I tried it by extrusion in operation it does not show the option IMPRINT FACES.Please suggest what I am missing?I have attached a screenshot of the problem.
April 17, 2016, 19:56 |
Rep Power: 13 |
you have to select imprints where you have 3 parts , 3 bodies.
Select all bodies, right click and create part. Once Part is created, click on it and you will see properties of that part. Use imprint instead of automatic! |
April 19, 2016, 11:06 |
SAMRAT MANDAL
Rep Power: 9 |
Thanks Kapi
Display Modes | |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 15:49 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
