October 17, 2009, 03:57 |
How to reduce skewness in GAMBIT?
Can i know how to reduce the skewness in GAMBIT?
October 19, 2009, 01:48 |
Maxime Perelli
Rep Power: 41 |
by knowing the reason of skewed elements....
and then correct the parameters or topology
In memory of my friend Hervé: CFD engineer & freerider |
April 23, 2016, 08:36 |
Rep Power: 10 |
Hi. I generate tet mesh with size function to create a mesh with more density on the solid-fluid interface. My mesh has 143 elements (0.02%) that are silver and their skewness is in the range of 0.95-1.
Is this skewness leads my results into inaccurate solution or it's OK? If so, How can I reduce the skewness? I'll be thankful for any advice. |
April 25, 2016, 02:16 |
Maxime Perelli
Rep Power: 41 |
check where are those cells localized.
If they are in the same area, then for sure you can fix the problem with some mesh settings
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
gambit crashed | mbgnfrx2 | FLUENT | 1 | August 13, 2009 03:31 |
Severe nonorthogonality and severe skewness problem | qtian | OpenFOAM Running, Solving & CFD | 2 | January 22, 2008 18:47 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
Generating big meshes with GAMBIT on NT | Andrew Ooi | FLUENT | 12 | February 2, 2000 22:26 |
