May 23, 2019, 03:21 |
Human body modelling/Meshing
Antonio
Rep Power: 9 |
Hi all,
I am trying to simulate the thermal environment inside an aircraft cabin with seated passengers. I have imported into design modeler some manikin model that I have found online. I was able to apply the Boolean and subtract from the whole inside cabin the bodies. When I imported the geometry into the mesher, I realized that the mesher is meshing inside the bodies which is not the correct procedure. My aim is to analyze the flow around the body from a thermal point of view for finding the best comfort. Any solution? I would like to thank you in advance for any reply. Kind Regards |
Human body modeling cylinder HVAC | rsslnt | Main CFD Forum | 0 | January 29, 2013 05:25 |
average human body heat in a room | alessandro.zomparelli | FLUENT | 1 | August 5, 2011 04:43 |
Help needed in modelling/meshing a body moving in a pipe which is driven by a fluid | hareshram.n | ANSYS | 0 | March 19, 2010 02:23 |
Human body into StarDesign | Con | Siemens | 0 | June 18, 2008 08:34 |
Human Body Simulation - Numeric Thermal Manikin | Andy Robertson | Main CFD Forum | 1 | March 19, 2001 10:23 |
