Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] 4 Pipes
Old   May 11, 2016, 13:50
Default 4 Pipes
mehdi benkabouche
mehdi199 is on a distinguished road
Hi , i have to model a geometry of 4 pipes like this
Q : can i make 4 T-Junction pipes & unite them with interface boundary ? if yes , is there any tuto on T-junction pipe ?
Thank you
mehdi199 is offline   Reply With Quote
Old   May 12, 2016, 01:17
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
here a tutorial on 3 pipes intersections:
https://www.sharcnet.ca/Software/Gam...guide/tg03.htm
Why do you want to unite them? If you create them from scratch, you create 4 pipes, and unite them, that's it.
What do you mean with interfaces? (interface in gambit, is't an interface between 2 fluids, but an interface between 2 meshes which are disconnected->interpolation)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 12, 2016, 15:23
mehdi benkabouche
Is this a good mesh ?
http://www.filedropper.com/defaultid1508
Old   May 13, 2016, 02:04
-mAx-'s Avatar
Maxime Perelli
just increase number of cells in the small pipes (at least 8-10 in the diameter)
Then it is ok, but it depends on your physics, especially turbulence modelling near the walls (check theory / y+)
Old   May 13, 2016, 15:37
mehdi benkabouche
the fluid don't move through the circle between big pipe and the small one
please help
Old   May 17, 2016, 02:26
-mAx-'s Avatar
Maxime Perelli
can you post a picture?
Thread Tools
Trackbacks are On
Connect two pipes with different space stap CFDDmitry Main CFD Forum 0 May 19, 2011 07:24
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 09:48
model of pipes inside pipe carmen FLUENT 0 January 22, 2009 10:27
cylindrical pipes Ben CD-adapco 4 June 16, 2004 11:25
45 degree pipes Amir Habibdoost FLUENT 1 June 10, 2003 12:40
