[DesignModeler] How to merge two bodies which are not overlapping in Designmodeler |
May 17, 2016, 11:23 |
Sean
Rep Power: 9 |
I'm trying to merge several bodies into one in Designmodeler, but I cannot do it because they are not overlapping. I want to do this because in the ICEM I want them to be meshed as a whole. Now they are meshed into seperate volume meshes and I have to manually select all these volume meshes to create a new part. I've tried named selection, but it doesn't work in ICEM, the volume meshes are still seperate. Anyone knows how to do it in designmodeler? Or other ways to make these bodies be meshed as a whole? Thank you very much! |
May 17, 2016, 11:46 |
Micael
Rep Power: 18 |
You can use "Form New Part" in DesignModeler if you want ANSYS MESHING to create a conformal mesh in-between all parts. This is useful if you want to apply different mesh option to each part, sizing as an example. Otherwise, in DesignModeler, Create->Boolean, then use "unite" operation to merge bodies.
May 17, 2016, 13:38 |
#3 | |
Sean
Rep Power: 9 |
April 21, 2017, 06:59 |
#4 | |
Lorenzo Mazzei
July 12, 2019, 06:02 |
Hitesh
Rep Power: 11 |
July 20, 2019, 03:07 |
check weather contact with bodies are correct.
design modeler, icem cfd, merge mesh |
[ANSYS Meshing] Overlapping Bodies error | suyesh | ANSYS Meshing & Geometry | 6 | July 24, 2018 02:03 |
[DesignModeler] Merge bodies in 1 while keeping the edge cuts | enayath | ANSYS Meshing & Geometry | 3 | September 6, 2015 19:30 |
Scripting Designmodeler - create skin out of line bodies - named selection | USER1234 | ANSYS | 0 | May 20, 2015 03:40 |
[DesignModeler] DesignModeler: Merge two named selections | Elgaard | ANSYS Meshing & Geometry | 15 | December 8, 2014 18:19 |
How to merge bodies | Oxmox | ANSYS Meshing & Geometry | 4 | August 20, 2010 05:21 |
