May 18, 2016, 11:17 |
Extract curve from part
Paurnamie Samarakone
Rep Power: 10 |
Hi everyone
I'm meshing a blade on Ansys ICEM. I need to extract the curves of my part so I can associate my blocking's edges to the part's curves. How can I do this ? Best Rgds Nat |
May 18, 2016, 18:39 |
B.H.
Rep Power: 11 |
Hi Nat, is your part only made up of surfaces? If you only have surfaces to work with, one option is to use "Extract curves from Surfaces" command in the Create/Modify Curves menu. For my example case, it only extracted curves when I checked the option "Create New" under "Extract Edges".
Hope that helps!! |
May 19, 2016, 05:47 |
Rep Power: 10 |
Hi niablis
I believe I only have surfaces yes. I imported a file.tin. Is that only a surface ? I will try following your instructions. Thankyou so much ! Best Rgds |
May 19, 2016, 05:54 |
Rep Power: 10 |
It indeed worked ! Thankyou so much !
Now I need to work on my mesh x) |
May 20, 2016, 00:34 |
B.H.
Rep Power: 11 |
Glad that it worked! Good luck on your mesh.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ANSYS Meshing] Identical meshes in symmetric bodies in multibody part. | aarvay | ANSYS Meshing & Geometry | 2 | May 11, 2012 11:15 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 04:59 |
How to maintain spacing along a new curve? | KB | Main CFD Forum | 2 | June 5, 2007 16:45 |
