May 25, 2016, 02:46 |
Problem with 2D analysis
sime
Rep Power: 9 |
Hi everyone
i want to simulate flow over simple 2D car , i import my geometry from solidworks to ansys design modeler, then generate it successfully ! but when i want to open ansys meshing , ansys workbench shows this error : ((PlugIn Error : No valid bodies found for 2D Analysis in the following parts : Surface Body , Solid)) ! after that i try a simple 2d sketch like rectangle and when i want to open ansys meshing , workbench shows same error ! Actually i can't open any 2d model in ansys meshing ! (i choose 2d in property but doesn't solve my problem) anyone can help me ? |
May 25, 2016, 15:01 |
sime
Rep Power: 9 |
is there anybody can help me ????
July 31, 2016, 18:51 |
vlg
Dear babri!
Did you use the forum search before asking this question? Please, check this post: http://www.cfd-online.com/Forums/ans...tml#post228887 1) Geometry - Advanced - Analysis Tyoe - 2D 2) your geometry should be in XY plane. If you want to use axisymmetric featre of FLUENT, the geomtery should lay in +Y semiplane. X should be the axis of rotational symmetry. |
Conjugate Heat Transfer Analysis Problem | redwanamit034 | FLUENT | 1 | June 16, 2015 23:39 |
Problem with ship motion analysis? | shameem | STAR-CCM+ | 7 | November 25, 2013 15:33 |
problem regarding analysis template loading in toolbox | Ashish22 | ANSYS | 0 | January 16, 2013 02:01 |
Convergence Criterion Problem in RC beam for NON LINEAR analysis | chagri | Main CFD Forum | 0 | September 14, 2011 09:26 |
Convergence Criterion Problem in RC beam for NON LINEAR analysis | chagri | ANSYS | 0 | September 14, 2011 09:24 |
