Create new surface to existing CAD file
Hello all,
I have created an CAD-file using Freecad, I want to create the mesh using snappyHexMesh (OpenFOAM) but run the case using Fluent. The problem is that I require two surface heat sources on the mesh which I havenīt been able to create using Freecad+snappyHexMesh yet. Can I create both surfaces in order to set them as surface heat sources in Ansys Meshing or in Fluent? I know that I can program an UDF in order to add volumetric heat sources (which I will have to do anyway). I would really appreciate your help. Thank you very much in advance. |
