[Workbench] preserve faces in volume
Old   June 7, 2016, 06:54
Default preserve faces in volume
Manu Chakkingal
manuc is on a distinguished road
Hello
I have a horizontal cylinder inside a cube. It is at the centre of the cube and the end faces of cylnder touches the vertical faces of the cube. I want to do a flow simulation over the cylinder (with heat transfer).
So I f I do boolean it is actually removing circular faces of area equal to cylinder top/bottom from the sides of cube. . SO if u look from one end you can see through the cube with cylindrical hole. But I need the end faces of cylinder to be closed. How do I approach it in workbench .
Regards
Manu
manuc is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
