June 16, 2016, 03:45 |
Deforming mesh
Rupesh Verma
Rep Power: 12 |
Dear Friend,
can any one guide in mesh deforming in 3d, for the water and plastic balls case. My email is roopesh99@gmail.com |
June 16, 2016, 08:03 |
Maxime Perelli
Rep Power: 41 |
any sketch of what you want to compute?
In memory of my friend Hervé: CFD engineer & freerider |
June 16, 2016, 08:59 |
Rupesh Verma
Rep Power: 12 |
Dear Friend, I want to do multi-phase simulation. I have simple pseudo-2D rectangular column [3d with smaller width]. In the column 500 particle of 0.25-1 cm diameter and water is inlet from the bottom and out from the top. I want to apply mesh deformation when particles movement taken place.
Thanking You. |
June 17, 2016, 02:40 |
Maxime Perelli
Rep Power: 41 |
for example:
http://cae-club.ru/sites/default/fil...alling-box.pdf http://www.emp.edu.dz/Manif_Scientif...i/rad/1-10.pdf
June 17, 2016, 05:49 |
#5 | |
Rupesh Verma
Rep Power: 12 |
Dear Friend, Can you give one udf based tutorial mainly based on grid deformation.
Thanks a lot Quote:
June 17, 2016, 08:19 |
Maxime Perelli
Rep Power: 41 |
Unfortunately I don't have any udf
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Liquid Volume Error when VOF + Deforming Mesh Used | NCle | CFX | 8 | June 8, 2012 13:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
