[ANSYS Meshing] Pipe Meshing
Old   June 30, 2016, 07:48
Default Pipe Meshing
Chaitanya
cysanghavi is on a distinguished road
I have a month of Background of ICEM, so I will try not to be stupid with my questions.
I am meshing the following geometry.
FV.PNG.
My meshing strategy, is to split the pipe into 4 small pipes and create blocks and use an o-grid block.
The Problem was in the last Region where i have to mesh an elliptical out of plane Profile with an circular Profile. the FV is :meshing_problem.PNG
The block structure was not providing good mesh in this Region. So I decided to mesh this Region from the mesh module.
Here, I tried to use the following things:
1. providing higher nodes on this elliptical surface.
2. proving thin cuts.
3. using refined mesh for the surface.
4. changing the global size, part size
I always get failure in the geometry and creates holes.
meshing_problem.PNG.
Even after a lot of resolving of the edges, using stitch, and match edges, creating ad deleting elements, the following elements, I could not delete/repair.
I create a very small part size, 1e-6. which also was not good enough.
Please give me recommendations to improve this, elliptical surface mesh.
cysanghavi is offline   Reply With Quote
Old   June 30, 2016, 18:57
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
in the mesh option you should add those two surfaces in "thin cut", I think it can help you solve your problem
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   July 1, 2016, 09:17
Chaitanya
read my thread. I tried this. did not work. there are still gaps. the geometry deviates a lot.
[ANSYS Meshing] Meshing a Simple Pipe With Different Diameters Adnann ANSYS Meshing & Geometry 2 May 16, 2016 03:38
[ICEM] ICEM "U" shaped pipe meshing mshaux ANSYS Meshing & Geometry 2 April 12, 2016 09:06
[ICEM] Hexa meshing branched pipe with different angles about its perimeter fascinatedbyCFD ANSYS Meshing & Geometry 1 November 19, 2015 10:11
[ICEM] Pipe 90 elbow joint meshing issue sihaqqi ANSYS Meshing & Geometry 25 April 17, 2015 04:59
Meshing of circular pipe in CFX-mesh Fatnes CFX 3 March 27, 2009 06:29
