July 28, 2016, 04:53 |
the error for smoothing process
松本貴大
Rep Power: 9 |
Hello, Everyone.
I make mesh, and such an error occurs when I am trying to smoothing process (smooth hexahedral mesh orthogonal). Would you tell me that is considered to be the cause of what. ------------------------------------------------------ an internal error has occurred : can't read "test_smooth(fams_attr, 0, NACA64A210_1)": no such element in array while executing "set val $test_smooth(fams_attr,$i,$part)"… … ------------------------------------------------------- Usage environment is ICEM CFD 16.0 Academic. |
2dimesion, error, icem, smoothing, wing |
The fl process could not be started because of UDF | majid_kamyab | Fluent UDF and Scheme Programming | 6 | December 15, 2015 08:42 |
Problem running in parralel | Val | OpenFOAM Running, Solving & CFD | 1 | June 12, 2014 02:47 |
error 262144 and unexpected disconnect when run on 2 nodes | Emily1412 | SU2 Installation | 1 | April 10, 2014 17:08 |
How to setup a simple OpenFOAM cluster? | TommiPLaiho | OpenFOAM Installation | 3 | October 27, 2013 15:15 |
dxFoamExec orphan process | bigphil | OpenFOAM Post-Processing | 0 | March 19, 2009 11:08 |
