July 28, 2016, 09:24 |
Volume meshing STL export
Bernardo Xavier
I've build a propeller on ICEM CFD and generated a volume meshing since is my goal is to 3D print this propeller. 3D printers reads STL mesh files, however, when I export STL mesh for the printer geometry software, I only see the shell mesh. I tried to import this same mesh into a new ICEM file, and only shell mesh was there. Can anyone help me if there is a way to export STL volume mesh? Thanks in advance. |
March 18, 2021, 18:16 |
Guanjiang Chen
Rep Power: 6 |
Hi, Do you solve this problem?
March 19, 2021, 12:10 |
Gert-Jan
Rep Power: 27 |
STL is a surface representation and not for volumes. So, in my opinion, this is not possible.
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
Unable to install OpenFOAM 1.6-ext | Maimouna | OpenFOAM Installation | 23 | May 8, 2014 05:47 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
