[TurboGrid] 2D linear cascad in TurboGrid (Meshing)
Old   September 10, 2013, 01:44
Default 2D linear cascad in TurboGrid (Meshing)
Adrian
Adde84 is on a distinguished road
Hi!
I have a problem that I hope anyone can help me with.
The problem is that I would like to "mimic" a a 2D Blade-to-Blade calculation in CFX by using TurboGrid.
My idea is to mesh a linear cascade section and set the end wall (hub & tip) boundary to symmetry. (Ideally can the cascade span be wery short (2 cells?)).
The problem is that when using turbogrid the hub and shroud will be swept and therefore not suited for a symmetry bundary.
So is there any way to have straight endwalls in TurboGrid that can have symmetry boundary condition?
Regards//Adde
Adde84 is offline   Reply With Quote
Old   August 16, 2016, 17:39
Jack
Jack001 is on a distinguished road
I am wondering this too. Any luck in finding if this is possible?
Jack001 is offline   Reply With Quote
Old   August 21, 2016, 11:57
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
make the inlet and outlet as hub and casing. this way you can trick turbogrid and get the required mesh in it.
Far is offline   Reply With Quote
Old   August 21, 2016, 12:02
Jack
Hi Far,
Thanks for your reply - I'm not exactly sure how you mean - the only thing I can think of in terms of tricking TG to do it is to make a blade that is just 2D profiles stacked in 3D and then set the number of blades in the full annulus to something ridiculously high and scale up the the hub radius in order for the hub and shroud to have no curvature. Im not too sure about the robustness of this method though. Is that what you mean?
Thanks!
blade-to-blade, cfx, linear cascade, turbogrid
[Gmsh] Extruded Meshing fails (Linear search / could not find extruded vertex) Ijazu OpenFOAM Meshing & Mesh Conversion 1 March 18, 2015 07:15
A turbulent test case for rhoCentralFoam immortality OpenFOAM Running, Solving & CFD 13 April 20, 2014 06:32
suitable boundary condition for scavenging process? immortality OpenFOAM Running, Solving & CFD 3 January 25, 2013 19:10
how to modify fvScheme to converge? immortality OpenFOAM Running, Solving & CFD 15 January 16, 2013 13:06
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
