how to give nodes
Hello,everybody, I am facing a problem in meshing.. plz help me out
Problem: Flow between parallel plates the distance between plates=2 cm non-uniform grid= 0.5 mm up to 4 mm from wall = 2 mm up to c-line from above |
Hello Ankur,
you might have forgotten to explain your actual problem which needs help. Have a look at this thread http://www.cfd-online.com/Forums/ans...wers-here.html In case you haven't done them before, I strongly suggest you to do the tutorials which come with icem. With regards, Sebastian |
