mesh quality
hello,
after meshing, I can check quality by seeing statistics, mesh metric in this mesh metric, there are element quality aspect ratio jacobian ratio warping factor on which in between values of this mesh metric that the meshed object can say good mesh, better mesh, bad mesh, high-quality mesh, can anyone help me how to read this mesh metric thank you |
go to help section in Ansys and you will find your answer.
Also if you have searched threads with similar question, u wud have answers! |
I got the same issue unable to find the solution in the help section. Can you please help me out to reduce the warping factor(face warping value) and also skewness reducing factors. |
