Home > Forums > ANSYS Meshing & Geometry
[ICEM] Geometry in ICEM
Old   September 29, 2016, 12:42
Default Geometry in ICEM
Saurav Kumar
srv537 is on a distinguished road
i have created a rectangular surface of 180*32 mm^2, at a point i want to create a hole of radius 0.1mm so i have created a circle of 0.1mm radius and i have used segment/trim surface to cut the cirlce area form rectangular area, but i am not getting accurate hole. pls check attached image and help me what should i do?
Image: https://postimg.org/image/ip8vbeiv5/
thanks.
srv537 is offline   Reply With Quote
Old   October 8, 2016, 12:27
Umberto
cinclus is on a distinguished road
This is not the proper way to do it.
First set the points and the outer lines of your rectangle.
Then create a circle which is going to be your hole.
You will then create a surface using only the outer lines of the rectangle.
Procedure than changes depending on the kind of mesh you want.
Is is a hexa-structured or unstructured mesh?
cinclus is offline   Reply With Quote
Thread Tools
Trackbacks are On
[ICEM] importing a geometry from Turbogrid to ICEM c120613 ANSYS Meshing & Geometry 1 May 14, 2013 23:59
[ICEM] Export Geometry from the ICEM asal ANSYS Meshing & Geometry 4 February 3, 2013 09:01
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre powpow CFX 3 December 20, 2012 10:14
[ICEM] Why Icem can't craeate Unstructured 2d Mesh on Circular Geometry Jvb ANSYS Meshing & Geometry 6 January 2, 2012 12:41
workbench geometry in ICEM Ross CFX 6 November 2, 2006 07:51
