October 26, 2016, 17:07 |
Need Help in Meshing Control
Shen Xinyu
Hi guys. I'm doint a 2D problem where two surface bodies are bonded on a shared edge. After I did the mesh I found that it doesn't have continuity on the edge. I want the mesh in which two bodies have the same nodes on the edge, is there any way to do this?
I tried with mesh connection, it looks perfect like the one I want, buy after I clicked SOLVE, it can't work. Here is my mesh now, hope some of you may help me. Thanks in advance. |
October 27, 2016, 02:01 |
Stuart
Rep Power: 25 |
Put the two parts into a Multi Body Part in DesignModeler, this will share the edge and make a node conformal mesh.
October 27, 2016, 12:37 |
Shen Xinyu
Help me to choose between Ansys Meshing, Fluent Meshing or ICEM ? | pipolaki | ANSYS | 0 | December 6, 2013 08:12 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
[ANSYS Meshing] Meshing strategy for External Flows | Hybrid | ANSYS Meshing & Geometry | 0 | January 24, 2012 14:27 |
Line Control in Ansys Meshing | Oli | ANSYS Meshing & Geometry | 4 | November 17, 2010 15:35 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
