Problem with multizone method for Piston/Valve tutorial
Dear All,
I try meshing Piston/Valve Assembly tutorial using multizone method. However, when I use 2D surface blocking, I cannot generate surface mesh of PORT near Cylinder and GROUP (STEM+VALVE+SEAT). I realize that surface of PORT include 2 types (Faceted Surface and B-Spline Surface). The part of B-Spline surface cannot be meshed with 2D surface blocking. I also try to convert B-Spline surface to faceted surface but it is impossible. Do you have any advice for me to solve this problem? Thank you in advance. |
