[ANSYS Meshing] Mesh refinement in one direction
Old   October 31, 2016, 06:11
Default Mesh refinement in one direction
Spiker54321 is on a distinguished road
Hi everybody,
I have the problem that I cant refine my mesh in one direction. The mesh is uniform in all directions, but what I need is a greater resolution in vertical direction. Corresponding to the picture below, I need more "slices" in y-direction.
It seems to be a very simple task but I just can't find any solution.
It would be great if somebody could help me.
Spiker54321 is offline   Reply With Quote
Old   November 1, 2016, 03:52
Paritosh Vasava
vasava will become famous soon enough
You can introduce edge sizing and use bias.
vasava is offline   Reply With Quote
Old   November 1, 2016, 09:07
Thanks! Problem solved
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[snappyHexMesh] snappyHexMesh refinement regions ignored guitarbren OpenFOAM Meshing & Mesh Conversion 2 April 9, 2013 03:59
[snappyHexMesh] Weird snapping outside a refinement region jasimpson89 OpenFOAM Meshing & Mesh Conversion 0 July 29, 2012 20:46
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
