October 30, 2016, 20:24 |
problem with structured map mesh in gambit.
parham
Rep Power: 10 |
Hi everyone,
i have a circle with a square located inside the circle. My intention is to create a map mesh for square which is easy by gambit. however, when i want to use such a map mesh for the space between square and outer edge of circle, ab error occurs which says the face 1 (i showed you in the attached image) cannot be converted to submappable region. I also attached you the ideal mesh that I want as an example.any help would be appreciated. |
gambit, map mesh |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
problem importing mesh into gambit | tsm554 | FLUENT | 7 | December 3, 2010 23:15 |
mesh missing after export in gambit | morteza08 | Main CFD Forum | 0 | July 23, 2010 03:19 |
Problem importing GAMBIT mesh to Ansys geometry | David G. | CFX | 0 | June 19, 2005 07:01 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
