November 10, 2016, 10:09 |
Differenz BCs after mesh rotation
Hey everyone,
I have a small problem with my ICEM mesh. Just for comprehension: I have a geometry (periodicity 30°) where I have one inlet and one outlet per periodicity. So far so good. now I want to eliminate every third inlet. I wanted to rotate the Mesh and define every new created inlet as a wall. So here is my problem: first of all after my rotation there are many problems if I check the mesh for periodicity as it says no periodicity defined. the second problem is that i cant redefine the inlet as a BC because I only have one Inlet part after the rotation. Thanks in advaance, Cheers, Max |
bcs, icem, rotation |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 05:39 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
