Home > Forums > ANSYS Meshing & Geometry
[DesignModeler] Error import airfoil data
Old   November 16, 2016, 02:36
Default Error import airfoil data
Antonio
AntonioDesah is on a distinguished road
Hi All,
I apologize in advance if I picked the wrong section of the forum.
Anyway I am Ansys newbie. I am struggling to import a txt data file into Design modeler.
I have created a NACA airfoil data file through AIRFOIL TOOL online, with a close trailing edge, of 100 points. I have transferred the data into Excel, splitting into the columns and created this format :
#Group #n.point #x #y #z
1 1 -1 0 0
1 2 0.999013 0.000119 0
1 3 0.996057 0.000476 0
1 4 0.991144 0.001067 0
1 5 0.984292 0.001883 0
1 6 0.975528 0.002918 0
1 7 0.964888 0.004158 0
1 8 0.952414 0.005591 0
( I have reported only the first 8 points)
In total have 5 columns.
I have saved the the file in txt format, as all the tutorials suggest.
Also I have had a training session few days ago and I m following the same procedure of the trainer, producing apparently the same txt file he produced but I am not able to create the geometry whilst if I import his file everything is of course fine.Looking at the two files they seem to me exactly the same, with the only difference due to different airfoils.
I do : Concept--> 3D curve-->coordinates file.
I keep getting this Error: Error Reading coordinates file.
Could anyone help me.
I would appreciate any help.
Thank you in advance for any reply.
Regards
AntonioDesah is offline   Reply With Quote
Old   November 16, 2016, 10:16
Default [solved]
Antonio
The txt file must be saved as ANSI not UNICODE(it saves like that by default)
Old   November 29, 2016, 00:37
Default i need help figuring out whats the fault in my coordinate file.
Santuzza
santuzza is on a distinguished road
guys, i am a very new user, when i try to import coordinate file from txt, it says i have "error reading coordinates file". i dont know where is the fault...im using airfoil data for SD7062. Please help me anyone as soon as possible. i ll be very grateful.
santuzza is offline   Reply With Quote
Old   November 29, 2016, 04:14
Antonio
Hi Santuzza,
Try this :
  • Put comment # at the beginning of each column( such as #x, #y etc)
  • The last row must be 1 0 that means erase the column relative to x,y,z coordinates because they are the same of the first one( I am assuming that you have created an airfoil with closed trailing edge)
  • Save the file as ANSI not unicode.
Let me know if you keep on facing the same problem because sometimes could depend on the cell formatting in Excel
Thread Tools
Trackbacks are On
Lift coefficient with my 2.5D airfoil model never matches the experimental data. ktgfeel FLUENT 1 December 15, 2014 13:58
2D FFD Optimization RLangtry SU2 2 August 5, 2014 09:48
C4 airfoil data dragon Main CFD Forum 6 October 8, 2013 14:22
Problem with airfoil shape optimization robyTKD SU2 Shape Design 6 June 13, 2013 19:13
AIRFOIL DATA WAQAR MAHBOOB Main CFD Forum 2 August 11, 1998 13:28
