[ANSYS Meshing] Material coalescense for geometry simplification (Heat Transfer) |
November 15, 2016, 08:36 |
Dario
Rep Power: 9 |
Hi guys!
I'm trying to keep the temperature at a specific region of the interior of a device constant. It has a fan to regulate temperature and electronics and some structural elements surrounding the mentioned region. The geometries of the electronics and elements are pretty complicated, and could be detrimental to meshing and computation processes. The question is, would merging all similar materials into simple blocks of the same volume as the agreggate of all elements together affect the simulation notably? The airflow of the heating/cooling fan is not directed to those elements, so maybe this simplification could model the phenomenom correctly. Thanks in advance, Dario |
November 15, 2016, 17:06 |
Rep Power: 14 |
its always suggested to simplify your geometry.
Create small blocks representing different parts as its far easy to mesh and stabilize. Make sure you give right boundary condition to those blocks and you shud get close enough result. |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Domain and Material Settings For Nanofluid Based Heat Transfer | Shomaz ul Haq | CFX | 44 | January 3, 2018 17:29 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
