[ANSYS Meshing] Discontinuous free surface due to different mesh sizes |
November 23, 2016, 23:23 |
James N
Rep Power: 9 |
I am simulating an open channel flow using VOF model. I divide fluid domain into different zones and I use different tet mesh sizes for each zone. When I plot the free surface it shows a gap at zone interfaces (see attached). The mesh sizes of these zones are 0.8m and 0.5m.
Are there any ways to plot the continuous free surface in this case? Thanks in advance! |
November 27, 2016, 08:43 |
#2 | |
Quang Le Dang
Rep Power: 13 |
After that, when you open 2 zones, yous must choose "merge" |
November 27, 2016, 21:05 |
James N
Rep Power: 9 |
I used Rhino to created the geometry and DesignModeller to slice it into different zones and applied different mesh sizes to each zone, so it should be continuous.
What do you mean by "merge 2 zones"? |
November 28, 2016, 03:40 |
#4 | |
Onur Özcan
Rep Power: 12 |
Kind Regards, |
November 28, 2016, 05:33 |
James N
Rep Power: 9 |
Can you tell me where the "merge function" is? In Fluent - Mesh Interface - I used "matching" for mesh interface, is this the one you're talking about?
November 28, 2016, 05:38 |
#6 | |
Onur Özcan
Rep Power: 12 |
You can find the solution by merging them.! |
November 28, 2016, 06:27 |
Quang Le Dang
Rep Power: 13 |
Please, upload picture of your geometry before generating mesh. I just want to make sure your geometry is continuous. After that, I can show you more
James N
Rep Power: 9 |
But if I merge two bodies, can I still apply two different mesh sizes for each?
November 28, 2016, 06:36 |
#9 |
James N
Rep Power: 9 |
Here is the part of geometry where I applied "slice" operation. If my geometry wasn't continuous, how fluid can flow from one zone to another?
November 28, 2016, 06:42 |
#10 |
James N
Rep Power: 9 |
This image should give a better visualization of zone interfaces.
November 28, 2016, 06:51 |
#11 |
Onur Özcan
Rep Power: 12 |
[snappyHexMesh] Mesh around ship with appropriate free surface refinement | Hannes_Kiel | OpenFOAM Meshing & Mesh Conversion | 46 | October 4, 2019 07:28 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
