Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Ansys Meshing doubt
Old   November 25, 2016, 02:12
Default Ansys Meshing doubt
nonstopthinker is on a distinguished road
Hi all,
I am creating a 3d model for a fluid flow in a rectangular channel in order to validate results from a paper (refer attached pic COMPARISON.jpg). Now, i am encountering problem in the contact regions between the fluid and solid as I cannot define biasing on the common edge as shown in the figure (conjugatefig.png). The mesh i require taken from a journal paper is also shown. kindly help as to how I can achieve the same kind of mesh. the basic problem is that i want to isloate the common edge to the fluid part so that i can achieve biasing only in the fluid region and not in the solid region. This way i can remove the skewness in the mesh and achieve straight orthogonal mesh as shown in the reference paper. Kindly help.Thank you.
nonstopthinker is offline   Reply With Quote
Old   November 25, 2016, 08:34
Gweher's Avatar
Gwenael H.
Gweher is on a distinguished road
You need to slice your geometry in designmodeller before importing it into AM. To do so you can insert a plane and then use Create > Slice. You'll end up with smaller "blocks" that can easily be meshed and in your case you can then apply an identical bias for both fluid and solid geometry.
Gweher is offline   Reply With Quote
Old   December 1, 2016, 15:49
Originally Posted by Gweher View Post
Yes i did like that but i want to obtain a mesh similar to the one shown in figure..that is..i want to give biasing only to the fluid region and since the fluid region is biased, it automativally gives bias to my solid "blocks" through the 2 common contact faces between the solid and fluid. How to avoid this? How to avoid biasing of the common edge only for the solid block?
Old   December 2, 2016, 02:47
Gweher's Avatar
Gwenael H.
If you want to have a non-conformal mesh of the fluid and solid and be able to mesh them separately (and also imposing a different bias between the two domains) you need need to have them in different parts in DM.
So if you split your fluid and solid geometry you then need to create a part for the fluid and another for the solid each one containing the respective subdivided domains.
Old   December 6, 2016, 17:47
Sarang Dalne
sarangdalne is on a distinguished road
In DM, select the Fluid part in the tree and set the "Share Topology" option to None. In this way you don't have split the geometry but you will have separate fluid and solid edges/faces.
sarangdalne is offline   Reply With Quote
Old   December 14, 2016, 23:28
Yes but that creates a number of Contacts in Connections. Should I suppress them all? If i import like that into fluent, it createa interfaces. What should i do with that? Sorry for silly question. I have never worked with these contact sharing bodies. Thanks.
Old   December 14, 2016, 23:29
Yes multipart geometry will work but then it will create mutliple contact regions right? What do i do with these contacts and interfaces that are coming up in meshing? Is there anything particulary to be done? Should i just suppress it? Thank you.
Sent from my XT1562 using CFD Online Forum mobile app
Thread Tools
Trackbacks are On
[ANSYS Meshing] Mixed Order Meshing in ANSYS Meshing oozcan ANSYS Meshing & Geometry 0 August 9, 2016 06:56
[ANSYS Meshing] SHIP MESHING * using ansys WORKBENCH or ICEM CFD Ctunramran ANSYS Meshing & Geometry 1 February 23, 2016 08:06
Ansys airfoil meshing problem Salah87 ANSYS 0 August 13, 2015 02:49
[gmsh] Vertex numbering is dense KateEisenhower Open Source Meshers: Gmsh, Netgen, CGNS, ... 7 August 3, 2015 10:49
Using ICEM CFD to repair/edit ANSYS Meshing Kaaji1359 ANSYS 2 July 30, 2013 10:28
