[ANSYS Meshing] Mesh for conjugate heat transfer
Like Tree2Likes
  • 2 Post By PSYMN
Old   June 20, 2011, 15:13
Post Mesh for conjugate heat transfer
Hassaan Rafi
hassaan is on a distinguished road
I have made a 2D geometry and have meshed it in ANSYS 12.0
When i export the mesh to Fluent, there is no shadow wall at the solid-fluid interface. Hence, i do not get the 'couple' option in wall boundary condition ( as i am supposed to find).
Can anyone tell me the reason why this is so?
thanks in advance!
regards
Hassaan
hassaan is offline   Reply With Quote
Old   June 21, 2011, 03:34
Moonlight is on a distinguished road
Check īthe connectivity of the faces. If you are a GAMBIT user, the color of the line between two faces should be pink.
Moonlight is offline   Reply With Quote
Old   June 24, 2011, 12:58
Default Multi-body part...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I assume you are using ANSYS Meshing in Workbench...
If you have separate parts, it will mesh them one at a time and the edges won't really be connected. You need to combine these into a multi-body part so they will be meshed together...
There are other posts about how to do this, or you could check the help...
Mazze[ITA] and rasekh64 like this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   June 26, 2011, 01:53
Hassaan Rafi
Yes I am meshing ANSYS workbench and i did sort out the problem
But now i cant seem to mesh the tube bundle. A straight pipe without bends is meshed easily but one with bends gives an error. Is there a different method to do this?
Help will be greatly appreciated Thanks!
Old   June 28, 2011, 13:50
PSYMN's Avatar
Simon Pereira
Have you specified the mesh method? Perhaps "automatic" won't generate a swept mesh, but specifying swept, along with a source and target surface will do the trick...
Or you could try "MultiZone".
Old   August 12, 2011, 10:10
josh hd
eaxja is on a distinguished road
Hi i recently saw ur post on ansys mesher and how u solved the problem such that u get a coupled wall between two interface (eg solid and fluid) i am also using ansys mesher and i would please appreciate it if you could explain to me how you solved it..... Thanks
eaxja is offline   Reply With Quote
Old   July 6, 2015, 04:13
Default conjugate heat transfer
ressan
wethiq is on a distinguished road
Hi, I work model contain fluid and solid wall when I run in fluent the heat don't transfer from wall (hot) to fluid (cold) in which I mesh each one separately. what wrong ?
wethiq is offline   Reply With Quote
Old   December 4, 2016, 08:56
Default Connection between two region
Mohammad Jam is on a distinguished road
Hi
I know this thread is old but i need your advice!
Could you solve your problem? I have same problem! I meshed two region in gambit and when i run my case no heat flux cross the boundary. And just one region have rise in temperature.
Any idea?
Thanks in advance
Mohammad Jam is offline   Reply With Quote
Old   December 4, 2016, 11:46
Antanas is on a distinguished road
Originally Posted by Mohammad Jam View Post
Hi
Any idea?
Thanks in advance
You should create interface between cell zones.
Antanas is offline   Reply With Quote
Old   December 4, 2016, 16:07
Hi Antanas
Thanks for your kind response
What kind of software should i creat interface?
I am working with gambit And i defined internal boundary condition between common face.
When i use hex grid for both region it is ok with internal bondary condition for common face but when i use tri mesh it doesnt couple!
Any idea is welcome
Best regards
Old   December 5, 2016, 01:03
Hi Antanas
Any idea is welcome
Best regards
This is done in your CFD software (for ex. Fluent, CFX).
Old   December 5, 2016, 03:50
Hi
But i use openfoam software
Regards
Old   December 5, 2016, 04:37
Hi
Regards
I never used OpenFOAM. I bet it has kind of manuals/guides, try search there. Also there's dedicaded forum here where you can ask questions.
ansys 12.0, conjugate heat transfer, heat transfer, interface-wall ids
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Help with mass transfer in heat and water vapor exchanger mullenc525 CFX 7 January 25, 2011 23:26
need papers on heat transfer George Main CFD Forum 0 November 27, 2008 07:42
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 05:09
