[ANSYS Meshing] Meshing a Circular Face by Mapping it |
December 5, 2016, 12:07 |
Rep Power: 9 |
Hello.
I'm trying to generate a certain mesh for a circular geometry. The solids I am modeling are helical wires conforming a cable (one straight central fibre and two layers of wires around it). I want to map the sections of each wire but I have no clue how. I've looked everywhere on the internet but there's no explicit explanation on how to do it. I generated the geometry in AutoCAD and imported it to ANSYS 15 and then opened the project in ANSYS 17.2. I would love if you can help me on what to do with each circular face in order to get the meshing I need. This is the meshing I'd like to achieve: Regards. |
December 5, 2016, 12:44 |
#2 | |
Rep Power: 18 |
But to get what's on picture you can split geometry to pieces and use Sweep method. |
December 6, 2016, 13:25 |
#3 | |
Rep Power: 9 |
Thank you for replying. I get what you suggest. The second option (splitting and a sweep method) sounds reasonable but I'm not sure how to achieve that. Regards. |
December 6, 2016, 16:42 |
#4 | |
Sarang Dalne
Mesh the quarters in the numbered sequence. You can record the meshing sequence using meshing worksheet, so that you can replay the same sequence automatically next time you mesh. |
January 4, 2017, 11:48 |
#5 | |
Rep Power: 9 |
Is there a way to tell the program that the nodes in one body (that comes from one of the fibres of the cable) that is adjacent to another one node in the opposite face are the same? Is there a way to, through the mshing, discard all the internal faces of the divisions of each body? I know I can just make all those connection as Bonded but still that is more CPU usage. Best regards. |
January 4, 2017, 15:45 |
Sarang Dalne
Try using node merge under mesh edit tool
January 4, 2017, 15:59 |
Rep Power: 9 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
