December 10, 2016, 15:42 |
YPlus
A
Hi friends, I am simulating ANSYS CFX centrifugal pump rotor, I use ANSYS MESHing, my logarithmic layer Y + 500 is 5.05e-3 with 20 prism cells, in ANSYS POST I check the YPlus values of Inlet, Outlet between 30 and 50, however, in the region of the blades I found values of Y + of 700, I tried to reduce the value of the first layer in the mesh, but with no result! What can it be? Does anyone know how I solve this problem?
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
OF 4.0 multiregion case calculate yPlus | pbnuclex | OpenFOAM Post-Processing | 6 | July 16, 2020 04:27 |
Yplus adapt | rafash2 | FLUENT | 0 | June 12, 2016 07:25 |
which yplus (SST) | sanchezz | CFX | 17 | January 11, 2010 04:45 |
heat transfer coefficients with "bad" yplus | Andrew | Main CFD Forum | 4 | April 8, 1999 04:43 |
