Home > Forums > ANSYS Meshing & Geometry
[ICEM] ICEM - Wing - hexa mesh
Old   January 9, 2017, 08:03
Default ICEM - Wing - hexa mesh
Michael
majkers is on a distinguished road
Hey guys,
I am currently trying to mesh a 3D wing inside a sphere domain.
I have come across some problems. Namely I am having troubles with O-grid around the wing. Please see the attached screenshots.
I attached all the edges to their correspoding curves after i had created the o-grid around the whole wing. As you can see in the picture Mesh_Problem something went wrong with the O-grid around trailing edge. If I move the blocks, it will change a bit around there but I will get elements with negative determinant. Anybody knows how to solve it? Should I attach some more pictures?
Michael
majkers is offline   Reply With Quote
Old   January 10, 2017, 04:54
Sebastian Engel
bluebase is on a distinguished road
Hi Michael,
more pictures of the area of trouble would definitely help.
The counts on the blocking in the last picture don't match. Can you show a picture with "scan plan"?
i would also try to assiociate the trailing block face directly to the trailing edge surface.
With regards,
Sebastian
bluebase is offline   Reply With Quote
Old   January 10, 2017, 14:35
Michael
Hey Sebastian !
Thank You for Your reply !
I tried to associate the block's surface to the trailing edge's surface but it didn't change anything.
Of course, I see no problem in adding more pictures but first I need to ask You to be more precise. Could You please tell me what do You mean by saying the block count don't match? And the other thing is that I don't actually understand what is that so called "scan plan". If You are willing to answer those short questions, I will add other pictures right after Your reply.
Thank you
Michael
Old   January 11, 2017, 08:26
Sebastian Engel
Hello Michael,
have a look at your picture:
On one side there are many elements. On the other side only a few hugh elements. From this picture, i cannot get an idea how these are attached, or, whether i miss something.
The feature scan planes (sorry forgot they named it in plural) is found in the context menu of premesh:
You can inspect planes of element by selecting an edge which is normal to a wanted plane. The you can move the plane element by element layer on that edge.
This tool might helping in finding a problem in the associations.
With regards,
Sebastian
Old   January 11, 2017, 10:20
Michael
Hey Sebastian!
I am adding more pictures as You requested.
In the picture called Dissassociated You can see what happens when I dissassociate the block's edge from the geometry. To be more specific from the curve representing the trailing edge. Its obvious that this particular association causes the problem but I have to admit I have no idea why.
The other pictures captures the scan plans.
Michael
Old   January 11, 2017, 10:25
Michael
I am also adding the picture capturing the association of the blocks around the wing.
Michael
Thread Tools
Trackbacks are On
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 28 May 7, 2017 16:01
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to mesh a swept wing in ICEM? kepeng ANSYS Meshing & Geometry 0 April 24, 2010 12:34
ICEM HEXA to CFX-PRE mesh export pb jaber ANSYS Meshing & Geometry 0 April 2, 2009 17:21
ICEM hexa mesh 2d car example icem student Main CFD Forum 0 May 11, 2008 19:17
