[ICEM] Meshing a 'high angle ratio' triangular surface
Old   January 13, 2017, 09:35
Smile Meshing a 'high angle ratio' triangular surface
Simon
jchan033 is on a distinguished road
Hi everyone,
As the subject indicates I wish to mesh a triangular surface (currently working on 2D), but because my triangle has a high 'angle ratio', meshing it creates very skewed cells.
I am aware of Y blocking, however it still gives very skewed cells.
Anyone can advise on this? (maybe I don't even need Y blocking?)
Thanks for reading!
Cheers,
Simon
jchan033 is offline   Reply With Quote
Old   January 13, 2017, 13:49
Antanas is on a distinguished road
Try to move vertices
Antanas is offline   Reply With Quote
Old   January 14, 2017, 09:04
Simon
Hi Antanas,
Thanks for responding!
The attached is the result of your recommendation; any more advice you think would help? It still is skewed quite a lot.
Cheers,
Simon
Old   January 14, 2017, 11:33
Hmm... Try to move this split closer to corner and add additional splits to the right of it.
Old   January 15, 2017, 22:34
Simon
But in the end I still need to settle with a rectangular block of..."high parallel length ratio", which will lead to a very small minimal angle (fluent takes 18 degrees or more yes?)
Is there any other recommendation that you can think of?
You may refer to the attached pic, I'm trying to mesh the "Stenosis" part
Thanks!
Old   January 16, 2017, 00:40
Simon
Thanks!
I've tried editing the geometry...but I think its the nature of the geometry that causes this difficult meshing.
It's a curve, so like a circle, it will slowly go to an angle less than 18 at some point...any advice?
Old   January 16, 2017, 06:53
So you've got almost zero angle, it's very bad. Try to avoid this.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 12:05
[Other] 3d high lift meshing linyx ANSYS Meshing & Geometry 1 April 7, 2013 03:36
Grid deformation for high aspect ratio grids praveen SU2 Shape Design 5 February 15, 2013 19:50
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
