[ICEM] Is this hybrid mesh easy to create with ICEM or Ansys meshing ?
Old   January 16, 2017, 07:39
Default Is this hybrid mesh easy to create with ICEM or Ansys meshing ?
aero_cfd is on a distinguished road
I would like to create a mesh similar to the one in the picture attached, so far I couldn't get one similar, could someone walk me through the process to obtain it in Ansys meshing or ICEM ?
Thank you
aero_cfd is offline   Reply With Quote
Old   January 16, 2017, 12:35
Antanas is on a distinguished road
Thank you
What's the problem?
Antanas is offline   Reply With Quote
Old   January 16, 2017, 19:00
Originally Posted by Antanas View Post
What's the problem?
I don't have this mesh , it is just a picture of what i want to create.
Old   January 17, 2017, 02:17
And so what? It's simple tetra mesh with inflation.
Old   January 17, 2017, 04:54
I have a NACA0012 with zero trailing edge thickness, ansys meshing didn't give a good mesh using tetra mesh with inflation, what i want to do is mesh the surrounding area of the airfoil with quad elements and the rest with tetra , however in ICEM the connections between the elements of quad zone and Tri zone are not aligned and tetra cells are more concentrated around leading edfe and trailing edge .
Old   January 17, 2017, 05:11
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Like He said it's a simple unstructured mesh. Its not quads you see in the boundary layer. It is prisms. First generate the tris. And then add inflation layer using prisms ( this is the quad layer you are talking about)
shereez234 is offline   Reply With Quote
Old   January 24, 2017, 08:06
Is there any tutorial available to this in ICEM ?
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
[ICEM] The ICEM Guide for CFX Users JuPa ANSYS Meshing & Geometry 11 September 4, 2017 09:43
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 05:31
[ICEM] 2d Aerofoil meshing in ansys ICEM syler3321 ANSYS Meshing & Geometry 2 February 3, 2012 01:59
