[ANSYS Meshing] Interior interface between three named selections ? |
April 6, 2017, 03:44 |
Rep Power: 9 |
Hi everyone,
I'm havin a hard time editing a mesh. I did some changes on an existing geometry, updated the mesh, changed a little bit the named selections, and then exported a new .msh file. But when i look at the texte of this .msh file, in the end, (where the interfaces are) i read to lines that are very confusing to me : (45 (97 wall extmixed-fcuve-varcuve)()) (45 (98 interior extmixed-fcuve-val_tireslat-varcuve)()) You can see here 3 named selections that i defined or were defined before : * extmixed-fcuve (already existing before) * varcuve (alredy exixting before) * val_tireslat (that i defined) varcuve and val_tireslat are two body selections. extmixed-fcuve is a face selection (it is the major part of my outer boundary) I'm normally supposed to end up with just a "wall extmixed-fcuve" (that's how it was before). I can't figure out what's wrong I attach some pictures so that you can see better wha'ts going on. Help please ! |
April 10, 2017, 05:12 |
Rep Power: 9 |
I finally solved the problem.
If anyone is interested, you can just ask me to know how i got rid of this |
April 10, 2017, 07:46 |
Jammy
Rep Power: 9 |
Hello Sir,
I am new to gambit and want to know the basics of meshing like what interval count should I use? Difference between interval count and interval size. Grid independent study. Can you please help? I am highly interested in CFD. Also is Gambit 2.4.60 valid these days to draw the geometry? Kindly reply. |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
