grouping edges for meshing
I have a large number of edges to be meshed the same manner. the edges are almost the same length. they are not being picked by "parallel" as they are not such. i can pick them one by one in the "copy to selected" mode.
how to keep the once picked edges linked so i could change the node number on one of them and it will apply the same settings to all the once selected edges. this way i can change the nodes number several times to see how it works out for me. |
I'm not sure if it is possible to group edges. But you could maybe use a replay file so you'd only have to do the copying once.
hey
tnx a lot for your promptness ill try this however, i wonder if the grouping option is anyway available as the one you have proposed, though will work, still seems like "they probably know how to do it in a more straight forward way" :-) thanks again |
