copy block
hey
im trying to copy the block (bottom up way) but while copying some of the block get the same number as the original one and then when e.g. deleting one of the copied, the original is also deleted (as is numbered the same way). how to avoid the numbering issue? |
Maybe it works. After you copy blocks apply this step; Blocking > Check Blocks > Method: Run Check/Fix I have experienced same problem. In this way I solved the problem. I wish you good work. |
N+
hey
thanks for the response i also think the renumbering can help - will try it too |
