[ICEM] Delauney Mesh from Octree Mesh- Can we bypass? |
March 13, 2017, 22:30 |
Vish
Rep Power: 13 |
Dear All
I am currently learning CFD meshing primarily through ICEM and am now on tet meshes. My question to you is regarding generating Delauney mesh. We all know that Delauney mesh requires a surface mesh. Generally, we use Octree mesh first, delete the volume mesh and then create the Delauney mesh from the remaining (surface) elements- perhaps after smoothening. However, we know that Octree mesh needs a closed geometry- no yellow curves. So can we avoid Octree mesh altogether by creating a shell mesh first, and then launching Delauney? Will this strategy work in the case of yellow curves- where Octree will fail? Thank you. Last edited by anand32; March 13, 2017 at 22:31. Reason: Did not want to show my true name |
March 13, 2017, 23:40 |
Ghazlani M. Ali
Rep Power: 28 |
Yellow curve means there is no cap. So mesh will propagate. Your intentions are not clear. Yes you can create shell and then delaunay, this approach does not always work, it depends on the complexity of the geometry and sizing ( uniform sizing). Can you share some picture to show us your intentions. You know you can create a solid body then delete the volume mesh. You will end up with surface mesh only...
March 14, 2017, 06:07 |
#3 | |
Rep Power: 24 |
Another point: As we do not know your model single curves might also be legit in some rare cases. Imagine a 2D baffle surface e.g. |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 16:59 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[ICEM] Delauney volume mesh going wrong | Rohith Giridhar | ANSYS Meshing & Geometry | 1 | July 26, 2015 19:53 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
