named selection problem
Hi everyone.
I'm new in cfd. I am doing a simulation for a flow pass a truck that has a cyclist beside it. In geometry, I am using enclosure and subtract the truck and cyclist. I want to separate named selection between the truck and cyclist. I have tried to hide enclosure faces but i cant select each of the truck and cyclist faces because there are so many faces. So how can i create a named select each of them. Here is my geometry. http://imgur.com/a/tOdvl Thank you. |
The simplest way would be to select with a rectangular region. On the top ribbon there should be an icon with an arrow and a red dot. The options are available in the drop-down menu right next to this icon.
Thanks a lot vasava.
This really helps me. |
