March 11, 2017, 19:34 |
help with meshing please
Rep Power: 14 |
I have this system (see the pic)
Its a 4 parts system I will name them from inside to out side: 1-water domain through the pipe 2- pipe 3 fin 4 pcm (square) its a heat transfer problem. the heat move from the water to the PCM through the pipe and the fin or vise versa The question is. How to mesh the system with a good meshing method. Every time I receive an error in fluent your help is appreciated in advance Thanks |
March 12, 2017, 01:45 |
Uwe Pilz
Rep Power: 15 |
There are places at the inner wall of the pipe where you have "free" noded (not connected to pipe cells) or at least rectangular elements in the pipe wall with 3 nodes in a line. I don't see which is the case from your image. The first case leads to a incorrect mesh and the second one gives numerical instability.
Sent from my HTC One SV using CFD Online Forum mobile app
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
March 12, 2017, 08:53 |
Rep Power: 14 |
THanks piu58 for your reply.
the two pics have been taken for the same case but from different view. The first and last parts have been mished with Quad and the two in the middle with Tetra. Do mot ask me why, I am just guessing. Thanks |
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 11:38 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 05:09 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ANSYS Meshing] Icem meshing queries | Mfaizan | ANSYS Meshing & Geometry | 21 | July 30, 2015 23:10 |
