[ICEM] Curvature/ Proximity Based Refinement - Is there a method to this? |
March 14, 2017, 17:21 |
Vish
Rep Power: 13 |
Hi All
I am on the learning curve of ICEM CFD and have been asking questions here to get my doubts cleared, and so far you guys have been really forthcoming. I am trying to mesh a cylinder contained inside a cuboid with Octree based 3D Tet mesh.The cylinder is hollow and closed I understand that I am able to capture the curvature of the cylinder only when I activate the "Curvature /Proximity Based Refinement" in the "Global Mesh Parameters". When I change the " minimum size limit" to say, 0.4, I get 14 line elements on the circumference of the cylinder. If I change to 0.8, I get 4 line elements. Is there any way or any logic to predict apriori how many line elements will result corresponding to the minimum size limit? Or is it mostly trial and error. Thank you |
What is C.V. based finite element method | C-H Kuo | Main CFD Forum | 4 | September 19, 2022 14:06 |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
Code for most powerfull FDV Method | D.S.Nasan | Main CFD Forum | 6 | September 4, 2008 02:08 |
is there any method give node based velocity BC? | daniel | FLUENT | 2 | July 18, 2006 21:21 |
Boundary Conditions for LU-SGS Method Based on Overset Grids | Aiming Yang | Main CFD Forum | 1 | April 25, 2000 04:35 |
