Meshing in Ansys fluent
Old   March 26, 2017, 12:18
Default Meshing in Ansys fluent
Bukhari
Ali12345 is on a distinguished road
HI...I am doing hydro-dynamic analysis of an underwater vehicle(UWV). I want to refine mesh around UWV by dividing my fluid domain into sections.Can anyone please guide how to do it in ANSYS ICEM mesher. The image of domain I want to build is attached
Ali12345 is offline   Reply With Quote
Old   March 26, 2017, 12:45
A.MAROUF
Abderahmane is on a distinguished road
Well i recommand you not to split it in regions, try to have one mesh that is refined on the walls of your object and coarser else where, in ICEM you can at the first create block then divide it, after that create your edges (containing the number of elements) and there are some options to go from a refined to coarser mesh.
Try to keep a structured mesh because your geometry is not that difficult.
Good luck
Abderahmane is offline   Reply With Quote
Old   March 27, 2017, 05:38
Bukhari
Thankx alot for your response.Can u further elaborate how to create blocks or how to make mesh finer near walls of Underwater vehicle??I am new to Ansys and need support, please.
Old   March 27, 2017, 06:06
Post
A.MAROUF
Hey,
There are a lot of Tutorials on youtube, i recommand you to see the one with : ICEM Mesh for a Cylinder and NACA0012, try to follow the steps and i am sure that you will do it. if not you can send me your geometry and i will try to make you the mesh.
Good luck
Old   March 27, 2017, 07:57
Bukhari
bro I have tried alot using videos as well.Plz let me know your email ID for sending you my model.Plz try at ur end while I will also try again to mesh it.Thankx
Old   March 27, 2017, 10:25
A.MAROUF
i sent you my Email, look to your msg
Old   March 27, 2017, 15:19
Bukhari
dear bro...I have emailed you all data.plz check ur email
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 00:49
Ansys Fluent NACA12 Meshing researcher ANSYS Meshing & Geometry 0 April 23, 2016 03:33
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 05:31
gambit in Ansys FLuent 13 saharesobh FLUENT 0 August 1, 2012 15:30
Meshing In Ansys Workbench For Fluent (Refinement) FAU_OceanEng FLUENT 0 May 31, 2010 17:12
