[ANSYS Meshing] Converting 2D Quads to 3D
Old   April 5, 2017, 09:43
Default Converting 2D Quads to 3D
Stephen
stephenneill112 is on a distinguished road
I've got a wedge shaped strut within a domain that I've meshed using mapped face meshing (2D) to produce a quad-only mesh.
I've now extruded the 2D surface retaining all the original faces and tried to mesh it the same as before. The problem is I have an injector face in the centre of the extruded strut.
The problem is when I add the injector and the surfaces, the sweep no longer works. I understand why, because the source and target faces are different but everything is square so I'm sure it's possible, I just don't know how.
Thanks.
stephenneill112 is offline   Reply With Quote
Regarding regIOobjectRead.C at line 73 error while converting results to paraview hhh OpenFOAM Post-Processing 5 November 24, 2016 02:45
[CGNS] cgnsToFoam error when converting ICEM mesh glasenapp OpenFOAM Meshing & Mesh Conversion 5 October 13, 2016 22:37
[ANSYS Meshing] Converting to Parasolid using FE Modeller, qwe11rty22 ANSYS Meshing & Geometry 1 September 4, 2016 22:35
Converting scalarField to DimensionedScalarField manju819 OpenFOAM Running, Solving & CFD 2 March 21, 2014 02:04
[ANSYS Meshing] Method: Sweep with Quads peterputer ANSYS Meshing & Geometry 0 July 18, 2012 13:22
