[ICEM] Block refinement, single-edge elements
Like Tree5Likes
  • 1 Post By shereez234
  • 1 Post By FLA31
  • 2 Post By shereez234
Old   April 13, 2017, 14:00
Default Block refinement, single-edge elements
FLA31 is on a distinguished road
Hello everyone,
i am trying to mesh a Pipe (laval-nozzle) with a structured mesh using Ansys ICEM. I blocked the pipe with an o-grid. I want to refine a part of the nozzle using the block refinement tool in the Pre-Mesh-Parameters. The resulting mesh looks fine. When I check the mesh to find errors and possible problems i get single-edge elements exactly between the refined blocks.
Is there a way to eliminate these elements. Thank you very much in advance!
Here's a picture of the nozzle at the place where i refined the mesh.
FLA31 is offline   Reply With Quote
Old   April 14, 2017, 10:01
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
this wouldnt affect your results. ignore
FLA31 likes this.
shereez234 is offline   Reply With Quote
Old   April 19, 2017, 03:10
Thank you for your answer.
Due to the signle-edge-elements, the mesh isn't correctly imported into my solver (Star-CCM+).
After importing it looks like i get two different meshes.
saihasil likes this.
Old   April 19, 2017, 13:18
shereez234's Avatar
M Sereez
star CCM eh? never used it. Okay when you get error message click delete
Old   April 19, 2017, 13:23
shereez234's Avatar
M Sereez
is it a connection there between two curves or surfaces?
FLA31 likes this.
Old   April 21, 2017, 07:07
No there is no connection between any curves or surfaces. Somehow the cells between the normal blocks and the refined blocks disappear.
If i mesh it without the block-refinement, no single edge elements are created and there is no problem when i import the mesh to star-ccm+
Old   April 21, 2017, 10:13
shereez234's Avatar
M Sereez
Hmm I see what you are doing. When you refine like that a cubiod or cube gets divided into the factor of refinement. For example if a region of blocking had 16 cells and your refinment is 2 then they will change to 32 cells. but what about the edges in the next block? they dont match any more do they.
Why dont you use mesh edge parameters and increase the nodes manually or why dont you scale the mesh globally i dont know multiply it by like 1.2? rather than refine a single block
FLA31 and aero_head like this.
Old   April 24, 2017, 02:54
Using a block refinement the total amount of cells would be lesser, as if i refined the mesh by setting the mesh edge parameters. But as the first option doesn't work, i think i will try to refine the mesh as you proposed.
Thank you again for your help
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 11:27
[blockMesh] Mixer mesh - negative volume problem jadtwo OpenFOAM Meshing & Mesh Conversion 2 November 6, 2014 16:37
[CAD formats] how to call my .stl file in the terminal izna OpenFOAM Meshing & Mesh Conversion 21 July 9, 2013 16:17
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
