[ANSYS Meshing] Only failed to mesh aerofoil on vehicle model imported from Solidworks
Old   April 22, 2017, 07:25
Default Only failed to mesh aerofoil on vehicle model imported from Solidworks
Tash
nkr201 is on a distinguished road
Hi!
I am trying to simulate the flow over a vehicle front wing in ground effect using ANSYS. I have created the model in Solidworks (pic attached) - this is just a simple model for now but no matter what settings I try, it simply will not mesh.
Even with no add on settings, just with a fine relevance center I always get the following errors:
A mesh could not be generated using the current meshing options and settings.
One or more surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology.
One or more entities failed to mesh. The mesh of the bodies containing these entities may not be up-to-date. However, meshing might be successful on the other entities.
To create the model in Solidworks, I imported the aerofoil coordinates, converted the curve to a sketch and extruded the sketch.
My method in ANSYS is to import the Solidworks geometry, create an Enclosure and then using Boolean operations, splitting the enclosure in half and removing the aerofoil structure so there is one solid body (picture attached).
I have tried changing the body sizing, adding inflation layers, edge sizing, out of ground effect but I always get the same error. I have tried suggestions from other posts but none particularly talk about this error, or suggest reasons why it will not work.
Any help will be greatly appreciated!!
Thank you
nkr201 is offline   Reply With Quote
Old   April 24, 2017, 09:34
Paritosh Vasava
vasava will become famous soon enough
Have you tried using virtual topology? If you not then try and let us know how it goes.
Also, I recommend that first you try with uniform or fixed Advanced Size Function. It should give you some mesh (may not be the best one). Then, play with global, local face and edge sizing to get detailed mesh at walls.
vasava is offline   Reply With Quote
aerofoil, ansys mesher, ansys meshing problem
[ICEM] Problem with Hexa-Dominant Mesh in a 3D Voxelized Model bidi ANSYS Meshing & Geometry 0 December 26, 2016 04:00
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 sam.ho OpenFOAM Installation 35 April 5, 2014 15:31
Mesh, Solutions, Model, results doneatlast FLUENT 0 March 12, 2014 16:18
