Gambit Error: Running out of memory; the volume could not be meshed!
Old   March 28, 2017, 10:05
Post Gambit Error: Running out of memory; the volume could not be meshed!
Sumit Sharma
sumit.sh is on a distinguished road
I am trying to mesh a complex 3D geometry with a helical tube inside a cylindrical cavity with gambit 2.4.6; I split the volumes and made sure that the geometry is clean. I meshed the tube with hex/wedge elements with spacing 1 and was trying to mesh the outer volume (that of cylinder minus the tube) with TET mesh with spacing 1. And I encounter the error: "Unable to locate xxxxxx bytes of memory. The volume could not be meshed."
I know not many people use Gambit now but it'd be really helpful if some Gambit veteran could help me out here.
Things I tried:
>> Coarsen the mesh but encountered skewed elements.
>> Read somewhere that resetting the number of UNDO levels to zero might help. Tried that but no difference.
>> Read that running the journal file without displaying the graphics reduces the memory requirement but was unable to execute that. How to turn off the graphics and let the journal file run?
Some help would be really appreciated.
Thank you!
-Sumit
sumit.sh is offline   Reply With Quote
Old   March 29, 2017, 02:38
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Originally Posted by sumit.sh View Post
Things I tried:
Use Size function to refine the area where you get skewed elements.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   April 20, 2017, 02:00
Sumit Sharma
Thank you Max for the reply and apologies for the delayed response.
I did try that but was unable to use size function properly as the edge at which the size function was applied was a part of multiple volumes. I have switched to Ansys and was able to control mesh in a more efficient manner.
Thanks again for your time.
Good Day!
-Sumit
Old   April 24, 2017, 01:36
-mAx-'s Avatar
Maxime Perelli
Then you needed to apply SF as much as your number of volumes
gambit 2.4.6, meshing 3d, out of memory
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 10:44
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel Mehrez OpenFOAM Running, Solving & CFD 10 May 18, 2016 11:44
Lenovo C30 memory configuration and discussions with Lenovo matthewe Hardware 3 October 17, 2013 10:23
running out of memory in Gambit, Help!!! ahmet FLUENT 19 October 5, 2013 06:01
