May 8, 2017, 12:05 |
Infinite length of Block
Juneseob Lee
Rep Power: 8 |
Hello
i made a simple rectangular in ICEM and created block in 2d planer as following pictures. after that, the block is produced but it is not fit with rectangular shape but stretch to normal direction with infinite length how can i fix it? |
May 9, 2017, 07:57 |
Sebastian Engel
Rep Power: 20 |
Hi Anzel,
there probably are a few solutions. Use associate edge to curve with the snap vertices option. First associate the short edge in the front to a curve. Then select the infinitive edges and select the respective curves. That way the far points should be moved automatically to the geometry. Another way is trying to create the geometry in the same plane the 2d blocking is initialized. Though i hadn't had such a problem so far. With regards, Sebastian |
Turbulence length scale and integral length scale | rizhang | CFX | 2 | April 22, 2016 07:22 |
[blockMesh] Inconsistent number of faces between block | CrisMoreira | OpenFOAM Meshing & Mesh Conversion | 10 | April 28, 2015 19:06 |
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 16:37 |
foamLog not solving for Ux, Uy, Uz | aerospain | OpenFOAM Post-Processing | 5 | April 18, 2012 10:01 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
