-   ANSYS Meshing & Geometry (https://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Building volumetric mesh out of a closed surface mesh (https://www.cfd-online.com/Forums/ansys-meshing/187595-building-volumetric-mesh-out-closed-surface-mesh.html)
ghafarimahsa May 10, 2017 11:50
I have a closed surface mesh that I generated out of .stl file and I tried to create the volumetric mesh using Octree. My volumetric mesh result comes out of my smooth surface mesh and the results is very bad and Jagged .
johny0688 May 11, 2017 02:41
I had the same problem and I solved it partially. In my case it was due to the geometry problem. The surfaces wasn't connected and flood created mesh outside the model. For higher mesh sizing (which was hardly acceptable, but was) meshing was perfect. Try to decrease the tolerance of geometry (1e-9) maybe it will help. If some one know this topic better I'm very interesting in solutions.
btw
I guess you created the BODY region, didn't you?
Kushal Puri May 18, 2017 14:22
Originally Posted by ghafarimahsa (Post 648355)
Dont use Octree method to create a volumetric mesh, Use delauney method.
And keep Smoothing turn off.
