May 23, 2017, 21:59 |
Geometry
Abhishek Srivastava
Rep Power: 9 |
Hello Friends,
I am facing a problem in modelling a duct. I have to model a duct which takes inlet air along with dust particles from the ambiance. To show the ambiance i made a box which will suck air from all sides. The box has some part of the duct inside it while major part of the duct is outside the box. While i am trying to use the Boolean operation to make duct and box as 1 body, the duct part which lies inside the box gets removed and if i am solving the problem with 2 parts and 2 bodies the CFX setup shows error saying "2 isolated regions are found". I tried creating common interfaces but that too is not helpful. How can i run my setup without any such error? Or is there anything in the geometry which i can change. I think if somehow i am able to make the geometry as 1 body then the problem would be solved. Please give your best advises. Thank you in advance. |
May 25, 2017, 20:43 |
Svetlana Tkachenko
Rep Power: 14 |
Don't use Boolean. Just right-click the two different parts and click 'form a new part'.
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE | mariachi | ANSYS Meshing & Geometry | 5 | May 30, 2018 02:52 |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 13:02 |
How to scale and translate the grid of particle data and STL geometry | Saidul | Tecplot | 1 | January 11, 2015 21:15 |
Running CFD parallel. There is no geometry file! | CrashLaker | SU2 | 6 | April 10, 2014 03:08 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
