Home > Forums > ANSYS Meshing & Geometry
[ICEM] Will grid independency for one fluid be valid for any other?
Old   June 7, 2017, 01:35
Default Will grid independency for one fluid be valid for any other?
Shomaz ul Haq
Shomaz ul Haq is on a distinguished road
Send a message via Skype™ to Shomaz ul Haq
Dear all. Hello. Hope all are well. I have a question. This may seem a very simple question but I really don't know the answer. Will grid independency for one fluid (e.g. water) in a closed flow model be valid for any other fluid? Would be grateful for help. Thanks.
Shomaz ul Haq is offline   Reply With Quote
Old   June 7, 2017, 04:50
Alex
Kina is on a distinguished road
I am almost 100% sure that it will not be applicable. The grid independency is based on the theory that your mesh is fine enough to resolve every physics the model is able to capture. In case of another fluid you might have different turbulence scales and therefore you may need a different mesh resolution.
Kina is offline   Reply With Quote
Old   June 7, 2017, 04:59
Shomaz ul Haq
Thank you Alex. You are most probably right. But then why do I see people applying grid refinement for one fluid (water in many cases) and then applying other fluids for the same model keeping everything else the same in research articles. I don't get this. It is strange. Also you talked about different turbulence scales but my model is laminar. How would turbulence scales affect my grid independency? Hope you can shed some light on these two questions. Hope to hear from other seniors on this matter too. Would be grateful. Thanks.
Old   June 9, 2017, 02:06
Shomaz ul Haq
Dear all,
Hello. Hope everyone is great. Hope somebody could give an explanation to my last questions posted earlier. Would be grateful from some advice from senior experts. Thanks.
Old   June 12, 2017, 02:54
Shomaz ul Haq
Dear all,
Hello. Hope all are well. Can anybody help me out with my questions in this thread? Would be extremely grateful. Thanks.
Old   June 12, 2017, 03:20
BlnPhoenix is on a distinguished road
I agree with Alex that one should do a grid refinement study when changing the working fluid, because with the fluid the fluid dynamics change. BUT if the fluid has nearly similar properties one could make the assumption that the same grid is equally good.
So it would be simply a matter of time/cost saving. From my experience in practice it is already hard enough to convince the decision makers to do grid refinement studies AT ALL.
BlnPhoenix is offline   Reply With Quote
Old   June 12, 2017, 07:06
Shomaz ul Haq
Thanks a lot BlnPhoenix. I get it now.
Thread Tools
Trackbacks are On
[ANSYS Meshing] Grid Independency Check In Automatic/Default Mesh In ANSYS Shomaz ul Haq ANSYS Meshing & Geometry 0 February 22, 2016 13:37
Global scaling - grid independency testing Jenny CFX 6 December 10, 2013 04:52
time independency - grid independency hamid1 FLUENT 0 January 20, 2012 06:06
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow using unstructured grid hari Main CFD Forum 2 November 15, 2001 07:38
