July 2, 2017, 20:13 |
Parameter Blocking and Block Problem
Daniel
Rep Power: 9 |
Hello there,
I'm currently trying to mesh an one bladed pump impeller. But now I am facing a few problems. Just ignore if the meshing strategy isn't the best. I am just trying to get to know meshing with ICEM better by this little project The first problem is with the meshing parameter option. Two edges are not recogniced when I am using "To all parallel edges". The picture shows that there is a huge mesh problem in the corner. the vertices and edges are all associated with the curves so I don't know what to change. As I marked with white: the associated edges to the curve are also used as parallel what I don't understand. This should not be I guess. Maybe can someone give me a hint to solve this. The next problem is that I accidently deleted a block and now I can't undo this. Is there an option where I can make exactly a block in to this "place" by using the vertices or edges ? Appreciate all of your help Thank you ! |
[ICEM] Merge sheet with free block in ICEM | sagarmore | ANSYS Meshing & Geometry | 1 | November 22, 2021 13:29 |
[ICEM] Blocking technique. Issues of the day. | Zeppo | ANSYS Meshing & Geometry | 16 | June 14, 2020 09:56 |
[ICEM] Load blocking from Unstruct mesh problem | Micha32 | ANSYS Meshing & Geometry | 0 | October 4, 2011 07:55 |
[ICEM] Quest for seemingly simple Blocking (degenerate block) | la7low | ANSYS Meshing & Geometry | 0 | July 12, 2011 19:48 |
Blocking problem with ICEMCFD | Charbonnier | CFX | 1 | November 30, 2006 13:41 |
